I also have 4GB SDHC card and I know that it is not compatible with my camera and a 2GB should be. Although no matter what card I use it keeps doing the same thing. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message. Help me place I really like this camera and would hate to have to give it up.
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
SOURCE: new memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
SOURCE: I have Z612 Kodak Easyshare
I had the same problem when I bought a 4GB card to replace the original 2GB. When I took it back to BestBuy where I bought the camera, I was told that this camera could only use a 2GB card. So, I bought a 2GB card, installed it, and everything was fine.
SOURCE: My Z740 won't format my memory card. When I turn
My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
