I can not use my phone. Tuesday i drop my phone on the floor and after i put it back on i've got the mobitracker alarm and i can not put an password because i didn' t make one.I didn't even knew that i had something like this on my phone.I may downloaded without me knowing. What can i do? please help.
You have to uninstall the mobitracker app from your device, if you have access to your main device you should do the following steps to remove the mobitracker app from your device
1) You will have to first install software like X-plore to explorer the systems files.
2) Open X-plorer, turn on show hidden files and go to c partition.
3) Search for files with extension .dat
4) Look for file name ProcServ.dat and move it to memory card for backup purpose.
5) Go to application manager and try removing the application, it will work like a charm.
6) Now reboot your phone to make sure that everything is working fine.
if you don't have access to your device you most hard reset your device following one of this methods :
First method:
1- Power off your phone
2- Now press and hold Call button + End button + Camera button + Power button.
If you see logo Nokia on your screen, then release holded keys.
After that your device will reboots.
Second method:
1- Turn on your cell phone.
You should now type this code: *#7380#
Then press your lock code.
* The default lock code is 12345
After that your phone will reset and restarts.
Success!
Third method:
1- Press Power button, until your phone turns on.
2- After that press Menu button and goto Settings -> Phone -> Phone management -> Factory Settings -> Delete data and restore.
Confirm your decision -> press Yes.
That's all.
SOURCE: nokia x6 : freezes, operation of the phone is slow
My Nokia X6 is like so slow from day 1. It's been 3 weeks or so. So does anyone have an idea how to solve this prob?
SOURCE: I nokia x6 I was
Inorder tosolve your PUK problem, *kindly contact your service provider (customer care) *Tell your phone number and they will give your PUK code *Enter that code on your cell phone(Wall that ask puk code) *Then your phone ask another pin code&to verify,there you can type your desired code(say 0000,00000,1234,12345). * Then your phone will restart normally.... "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
SOURCE: i have nokia X6 16
Kindly try nokia master reset code : 12345. If it fails , just get the code by key in your IMEI number at :
www.nfader.su
or
www.nokialockcode.com/calculate.php
Regards, Jay
SOURCE: Hi, I use a 4GB
Hello Divinegoddes,
It seems that your phone memory card contains the virus.So scan your memory card using the anti virus installed in your machine.You can scan you memory card for antivirus using the Avira anti virus.Please download the anti virus from :
http://www.avira.com/en/free-download-avira-antivir-personal?
Download the .exe file from the above link.
Install the software in your computer. Remove the memory card from the phone and connect in your machine using the memory card reader and scan the card for viruses or malwares.
