Is the washer leaking on the floor? Or is it continuing to fill while the cycle is running or when its not in use?
If the water simply continues to run and won't shut off, this may be caused by a pressure switch malfunction or a water inlet valve that is leaking by. The following link explains how you can determine which one may be causing your problem:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_useCheck the small air hose that runs from the bottom right hand side of the wash tub to the pressure swtich. If this hose has come loose from the pressure switch from the air dome on the wash tub, the pressure switch will not sense the pressure differential coming from the wash tub as the unit fills. Also, if the air hose is cracked, ripped, split, or clogged somewhere, you will get the same symptoms.
If the water inlet valve is determined to be the source of your problem, follow the steps provided in the link on how to replace one. These are simple and inexpensive repairs. I've also included web sources that you can refer to for part numbers.
If the washer is leaking on the floor, you will need to remove the exterior washer case on this model washer In order to properly diagnose the source of your problem. Its not as difficult as it seems. The following link explains step-by-step how to inspect a top loader for leakage:
http://www.fixya.com/support/r3576648-washer_leak__top_loaderReplacement parts (if required) can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancpartspros.com
repairclinic.com
Prices can vary between these sites, so shop and compare. The first three sites on the list also include helpful exploded view diagrams to assist you in locating and identifying the parts you need.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
