Sewing Machines Logo
jacqui white Posted on Sep 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bobbin case problems
When emboiderying the bobbin case twists and jams pushing up the needle plate breaks needle and damages bobbin case have changed bobbin case changed needle rethreaded only use Janome bobbin fill. embroider very slowly.
sylviaivie
Level 3:
  • Janome Master 1,564 Answers
  • Posted on Sep 08, 2012
sylviaivie
Janome Master
Level 3:
Answers
1564
Questions
Helped
425788
Points
3583
Oh wow. That's definitely not good. Well you'll need to replace the bobbin case, and needle plate. Even the slightest burr can cause havoc. you could try smoothing down burrs with some fine sand paper but you'll need to replace the case eventually if you can't get this problem identified and fixed.
Next look for a build up or stray threads under and around the needle plate/bobbin area. Make absolutely certain you have the right needles for your machine.
4 Related Answers
Cheryl Westbury
  • Posted on Aug 22, 2008
SOURCE: My sewing machine will sew
Turned out I am an idiot and had my needle in backwards, leading to the tangling. No idea why the needle plate would not unscrew, but my superhero husband got it off!
s-e-g
  • Posted on Dec 06, 2007
SOURCE: Upper Thread Error
there could be thread caught in the tension disc in the top of the machine you can get the cover off to clear the thread but it is a bit tricky to get back on
Anonymous
  • 710 Answers
  • Posted on Apr 28, 2011
SOURCE: Janome computerized 4030 (2
It sounds like something on the bobbin case may have been knocked out of adjustment. I would take the bobbin case to a repair shop to have it adjusted. First, be sure you've cleaned all bits of thread that may have gotten caught in the area. Blow it out with compressed air if you have it. Then, start with a new needle and be sure you are threading the top correctly. Try it again and if a good cleaning and proper threading doesn't do it, then take the bobbin case in for repair.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Oct 17, 2011
SOURCE: janome memory craft 6500 sewing machine...all of a
Has the bobbin case dislodged and moved? there should be two red marks one on the bobbin case and one on the outer holder, are they lining up? Sometimes as these cases are held by a magnet, they will get dislodged and move slightly, especially in a jam up.
Take out the bobbin case and clean under it, then replace it matching up the red marks.
If the bobbin case has actaully been struck by the needle during a dislodgement, it may well pierce the bobbin case plastic, look for burring or marks on the outer flange area. If this has occured, the thread may catch on the burr as it comes over the bobbin and jam again.
You can buy a new bobbin case if yours is damaged or maybe just file the burring with an emery board (remove it from the machine first of course).
Lastly, check your needle hasn't been bent, burred, or put in backwards, any of these can prevent a stitch from forming.
If all the above fails, then it is possible that the timing has been knocked out and you will need to get it serviced by a technician.
The needle can't be turned backwards manually
The needle should only go up/down. Sewing forward or reverse involves the feed dogs grabbing and moving the fabric. On most sewing machines, you should never turn the hand wheel backwards. This can change the timing and damage the machine. Instead, try holding the Reverse lever or button then turn the hand wheel forward.
Since the sewing machine jammed with the needle bar at its lowest point, open the bobbin cover. If you see a loop of thread, try and slide that loop until it clears. If there are several loops around the bobbin/bobbin case, you might try carefully cutting the thread. If the fabric of your sewing project has been stuffed into the needle opening on the plate, try carefully clipping threads to loosen the jam.
If that doesn't work, then double-check that the bobbin winding mechanism isn't engaged. If the unit is still stuck, you might have damage to the various linkages/bearings between the hand wheel and needle bar. The problem may require taking the machine in for service.
I hope these ideas help. Please add a comment with the make and model of the sewing machine for further assistance.
(When you do get the needle bar to go up, you may want to change your needle. Also change the needle plate to the straight stitch plate if you are doing a straight stitch with a lightweight fabric.)
Why does thread keep breaking after a couple of stitches. Needle plate has damage.Machine and bobbin in correctly.
it sounds like a problem in your bobbin Sometimes if the bobbin is downloaded wrong way this will happen. Sometimes it could need cleaning lint and such under the bobbin casing. Hope this helps.
Fabric is pulled into the bobbin area
You have probably got a needle hole in your bobbin case....the black thing the bobbin sits down into. One common problem is when folks take off their stitch plate to untangle a jam up, the bobbin case is not held in the right position and the first stitch after the clean out jams the machine. Check you are position the bobbin case correctly and the bobbin case has not been punctured.
Husqvarna #1+ sewing machine, is breaking needles under throat plate
This could be bad timing, or the needle is not in properly.
Make sure that the needle is pushed up all the way, and in the correct position. If the needle is too low, it will break.
Also, keep the bobbin case door open to see where the needle is catching.
1helpful
My Singer 648 is having a problem with the bobbin thread getting caught up in the bobbin case and jamming the thread inside the case breaking the thread. Is there a solution to this problem? Thanks
try changing the needle
make sure the top thread has not come off the thread take up lever
try another bobbin
make sure the bobbin is turned the right way in the bobbin case
try rethread the machine top and bobbin
clean under needle plate and in the bobbin area for lint or threads
2answers
Kenmore sewing machine jams and breaks the needle
always make sure the needle is inserted correctly and all the way
up into the needle holder
try a different bobbin
make sure the bobbin case is inserted correctly in to the machine
if it's a front or side loading bobbin case
make sure the top thread has not come off the top thread take up
lever
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
1helpful
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
3helpful
The needle keeps breaking in my Yamata FY 910
The bobbin case rests on the lip of the hook and is is held into place by the position bracket. The position bracket is located at about 5 o'clock and has a small square end with a buffer spring. It must be positioned to hold the bobbin case securely and also allow the thread to pass through freely. It may be out of adjustment but may not.
If the bobbin case has turned, it is very likely to have suffered damage as it is made of a soft carbon fiber material. It not polished off, these damaged areas can snag the thread and jam the machine and create tension problems. Some gouges, burrs and needle punctures can be carefully sanded but you may need a new bobbin case. Use a 1500 grit sandpaper to smooth off the rough edges.
2helpful
Bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Apr 02, 2008 • Singer 2662
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
