SOURCE: problem with ford explorer alarm imobiliser
You should have a switch under the dash and then just turn it to the off position. If you don't or it doesn't work (like mine) then, there is 2 fuses under the dash, put the key in the ignition and turn it forward, pull one of the fuses out and then start the car that should reset it. Then you should be able to put the fuse back. Sometimes if you put the fuse back before starting it the alarm will just continue to try and reset itself, but not start the car. If that doesn't work I have a mechanic who can pull the whole alarm out and when hes done it would look like nothing has ever been installed. Hes very good. I ended having him take my alarm out when I had the same incident happen after the 2nd time.
SOURCE: Drivers power lock will not unlock with remote.
the door lock actuator is defective, they get really hard to move when they go bad, that is why the difficulty with the key.
SOURCE: lost car keys, how to replace ignition/door locks
Can u open the doors using the ignigtion key or is it two seperate keys?
SOURCE: Ford F150 remote key does not work after car battery
Should not have happened,
For the Factory RKE ( Remote Keyless Entry ) have you tried reprogramming the key fobs to your truck. The procedure is in the owners manual ( need all of them at programming time ).
This is stored in NVR, and should not need to be done, but worth a try.
If this is an aftermarket Remote start / alarm, check the owners manual for t on battery replacement. Have seen some off brand with strange battery ( truck's battery that is ) replacement steps.
SOURCE: 1996 Explorer anti-theft system won't disable
Try re-setting the computer...Disconnect the negative terminal of the battery and leave off for 5-10 minutes. This will allow the computer to reset. The charger may have interupted the signal or something.
battery is dead and I cant open the doors
