My machine stopped on a washing cycle with code E23 and two beeps. It makes a humming noise when i try to start the cycle. There's water in the compartment not being drained. What's the solution?
Thanks,
Nazmul
Hello welcome to Fixya
E23 means
The drain pump relay on the control board has failed.
Fix: Replace control board or wire!
you can see schematics and diagrams at the site below, and order parts from them if you want.
Or call service!
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Hello Robert Reische, thank you for your inquiry!
I understand that your Frigidaire washer is showing an "E23" error code. Based off the information I show "E23" stands for drain pump relay on board failed or wire off the pump. Which means you could have an issue within the main control board or wiring to pump. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance. Hopefully this helps. -Matt
To recall an error code,
Wake the machine by pressing any button Wait
5 seconds Press and hold the Start and Pause Cancel buttons
simultaneously Ail LEDs will go blank and after a few seconds the control will signal the
stored code using audible beeps and blinking LEDs. The control will repeatedly
signal the code, as long as the Start and Pause Cancel buttons are
pressed. A two-second pause between repeats affords you the ability to make
accurate counts to identify the correct error codes. you
may also have a code such as E47 or E24 etc.. Comme back with the code and I will explain what is the meaning of the code
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
you may also have a code such as E47 or E24 etc..
Thanks for the help! How do i replace the control board? Where is it located?
Nazmul
Error code e23 won't drain water
