SOURCE: IS there a reset code for a Sharp AR-507 copier,
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
SOURCE: Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
SOURCE: sharp ar 5516 maintenance reset
Hi sir; press 4-key as follow by order "#, interrupt,C, interrupt " then enter 20 then01, repeat 4-key again then enter26, then enter 36 press1
