IT SAYS WINDOWS FAILED TO START, A RECENT HARDWARE OR SOFTWARE CHANGE MIGHT BE THE CAUSE.
SOURCE: I am trying to install Vista on my computer
try hitting ALT f10 while turning on computer it will install factory software
SOURCE: RESTORING WINDOWS/BOOT MANAGER
Sounds like you have Vista. Here is a link on creating a Vista recovery cd:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
This link is a how to document on repairing the BootLoader:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+with+EasyBCD
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Windows Error Recovery
Using the Windows installation cd. Boot the system with the CD in the drive. When given the option select the repair option. This should correct the issue. Hope this helps & please remember to rate my answer. Thanks.
SOURCE: Enteri am having a big
I might advise you reformat the operating system of the computer, or check the peripheral devices for this computer if properly connected? You got a fatal error it means that there is something that is not reading by the memory of the computer.
SOURCE: window did not start
insert your Windows Installation Operating System Disc.
Reboot
Boot from cd/dvd.
Choose Windows Repair when prompted.
Follow the directions.....
That should fix it.
You got a hardware/software driver issue or corrupted windows OS files...
Actually it is not hard to fix this this problem What you will need to fix it is : 1- A 2gig flashdrive (I used a 2g and it worked,not sure if any other size works) First visit this link https://www.dropbox.com/s/t88gryfudq3741... (Thats my dropbox which contains the Windows vista Iso DO NOT EXTRACT IT , just put it on your desktop and leave it there. 2-Visit this link and download and download the usb installer(On the bottom of the page it will mark Download uii in a blue box) , this will turn your flashdrive into a bootable flash drivehttp://www.pendrivelinux.com/universal-u... 3-Run the program and it should look like thishttp://www.flickr.com/photos/100773530@N06/ (Make sure you select Windows Vista Installer and note that this will not reset anything on your victim Computer ) 4-Now in the select your iso option in the program select the iso which you downloaded from my dropbox by selecting browse AGAIN DO NOT EXTRACT 5-Now put your flashdrive in your computer and select the drive And when everything is done it should look like thishttp://www.flickr.com/photos/100773530@N06/ 6-Now select create and note that THIS WILL FORMAT YOUR FLASHDRIVE\ 7-Now you have a bootable flashdrive 8-Now insert your flashdrive into yoor victim computer and go into your Bios and set your usb as your first boot device by moving it first in the order (If you dont know how to do this visit this link) -http://www.youtube.com/watch?v=C8VZ95_XF... 9-Now restart your computer and it should mark Windows is Loading files on bottom of the screen Just leave your victim computer like this for about 10 - 15 minutes and it should just have a blank screen without the user accounts. 10-Restart your computer by pressing the button on the Tower and select Last known Good Configiration DO NOT TAKE OUT YOUR FLASHDRIVE and your computer will start normally 11-Take out your flashdrive and restart computer again and you are good to go When this works please vote thats all i ask Hope I helped you
