After repairing a cracked guide, printer fails to print, gives a "Replace cartridge" message. Replaced cartridge, printer stills fails to print, gives same "Replace cartridge" message!
Did you use a remanufactured ink cart.?
It was a "Trademark Kodak" box and the paper and cartridge were sealed. considering the repair I made to the "Guide", could there be an adjustment needed, though I didn't see or notice a way to adjust it. Also, my "Error Light" is a steady amber, not flashing!
I have a KodakEasyshare Printer dock, series 3. This cartridge slides out and you slide in the new one...., with some caution!
SOURCE: Replaced print head and cartridges and still not printing.
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side.
choose maintenance under general links and choose printhead cleaning. if this does not solve the issue,
call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost..
SOURCE: USELESS! I guess the life of an ESP 3 is up to a
Regarding the empty ink cartridges, ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Regarding the printer not being able to detect the size of the paper, you probably need a firmware update. Here is the support information from Kodak website.
And I have to agree with you, printers don't have a very long life cycle, but you should get at least 2 years out of it! Good luck!
