I have a intel celeron laptop, loaded up farming simulator and it does everything but as soon as i try to start it says giants stopped working
Unfortunately I don't think your pc meets the Graphics card requirements so you won't be able to run it on your laptop.
Product Requirements :
Farming Simulator 2011 any PC version, download or boxed
Windows XP (SP3) / Windows Vista / Windows 7
Intel-CPU 2 Ghz or higher
Nvidia Gforce 6800 Series, ATI Radeon x850, S3 Chrome 430 GT graphicscard or better (at least 256 MB VRAM)
1 GB RAM
1 GB free disk space
SOURCE: I got the Farming Simulator
have you tried to enter in the cd directory and run manually the setup? If so try to reboot the computer and try again. Can you try in a different computer to check if the problem is not from the CD?
SOURCE: I have just purchased a Microsoft train simulator.
the computer may not have all the proper drive data for the game, that or there may be a glitch in the game, check online to see if anyone has posted a downloadable bridge to fix that.
SOURCE: Farm simulator loads but lags
That sounds like a problem with your video card driver. Make sure you have the most up-to-date drivers for your system.
There are two ways to do this, the automatic way (not guaranteed to work) and the manual way.
Automatic way: Right click on My Computer>Properties>Hardware>Device Manager. Locate your video card and right click>properties. This should give you a pop-up window, and on the first tab you should see "Update Driver". This will launch the driver update procedure.
If that doesn't work (the driver update says your drive is up-to-date, or it can't find the driver), take note of the make/model of your video card, and visit the manufacturer's website (IE a nvidia card would be nvidia.com, etc). Go to the support/downloads page and find the driver for your card, download it, install it, then restart your computer.
If neither of those work, check the system requirements for the simulator and make sure you meet or exceed those requirements (exceed is preferable, obviously). Also try going into the options for the simulator and changing your graphics/resolution down a little bit to make it easier on your card.
SOURCE: where is the product code
the product code is on the back of the book when you buy the game.
it happens to me to
