Desktop pc previously on xp pro sp3
1. no audio device, if you sound card is integrated , first to CMOS inside look at sound card was disabled or not, then again consider driven of problem,
in device management Manager in look at is has yellow of question mark or is laments,, some words on double-click the device (into driven CD), click Update driven program, by prompted update can (don't said you does not yo).
also directly can be placed in the driver CD to install the driver, after installing your reboot should resolve the issue.
2, and if sound card is independent, first look card gold finger whether oxidation, as found gold finger gloss Dim found block rubber wipe to oxidation layer, again see PCI slot within whether has product dust, if has words with rubber blowing blowing clean dust, again with new of Yuan folding up to slot inside wipe about, then will sound card insert PCI slot within, must to plug tight, also no on for a slot try try. Determine Board connection when there is no problem, follow the steps to install drivers, in case of hardware damage alone will solve the problem.
i dont know how to get into cmos, and i dont have a driver cd, alls i know is the speakers worked fine when on xp and now dont, only a low crackling noise, and were the volume control on my desktop is the is a little red cross saying no output device installed or saomething along them words, the comp has recently had a new motherboard, with audio jacks built in etc i aint a clue about soundcard etc?
SOURCE: XP audio codecs
Hi Try this site www.nodevice.com, you can get basically any driver for any hardware on this site Hope this helps Regards
SOURCE: Dell Drivers XP drivers for vostro 1400 ..
Did you download the latest audio drivers from Dell.com? If not here is the link to the drivers for that device based off Vostro 1400 using Vista 32 bit Edition. http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=3&impid=-1&servicetag=&SystemID=VOS_N_1400&hidos=WLH&hidlang=en Hope that helps. If not let me know.
SOURCE: How to install XP on pre loaded Vista in HP Laptop
I bought a cheap Compaq laptop that came with Vista Home Premium. The speed was horrendous! Anyway, I received the same no hard drive found error. To solve the problem, I went into the system config (BIOS) by pressing F10 on startup, and turned off SATA hard drive support (its supposed to make the hard drive run faster), I rebooted, inserted my Win XP Pro disc and viola, it detected the hard drive. I would say that the laptop runs a good 40% faster than before. Vista is a big no no when it comes to low end laptops built for word processing and internet browsing.
SOURCE: Recording Issues In Vista
Microsoft moved the particular option that you need to enable since Windows XP, and have also changed its default to MUTE.
To hear what is playing through MIC IN...
I really hope that this has solved your problem, if it has not, please let me know and I will do my best to help you further. Good Luck!
SOURCE: xp pro no sound
Hi Yoni,
The most likely reson why you still don't have sound is you were not able to install the sound card driver properly. I suggest you goto CONTROL PANEL then click on ADD/REMOVE PROGRAMS then uninstall all the software/drivers related to your sound card, afterwards restart the computer. Then try reinstalling the sound driver again using the correct Sound Card driver disc. It should work.
Of course downloading the latest drivers for your sound card is always a very goof advise. Check your computer manual or your computer's specifications to know what sound card you actually have in the system. Even calling for techsupport if you bought this from a manufacturer is even better. If you have the information. Goto your computer manufaturers website and get. Otherwise you can download it from the soundcard manufacturer's website directly. Make sure to download the correct driver, since it's not going to fix your problem if you get the wrong one and it may cause problems.
I also suggest that you check if your sound card is still detected by the PC and if it's showing up. You can do this by going to right-click on MY COMPUTER, select PROPERTIES then goto the HARDWARE tab then select the button for DEVICE MANGER. Check if there is any "?" question mark symbol or "!" exclamation mark symbol. Most likely that is your sound card. If there is a red "X" then the device is disabled, you can right-click on it thn select ENABLE to mak it run again. If there is not an item with any of those symbol, you can check SOUND VIDEO AND GAME CONTROLLERS category and see if your soundcard is listed there.
For most systems there is an option in the BIOS to disable the soundcard (especially if its integrated!) check the BIOS to see if the soundcard was disabled there. Check the manual of your computer or motherboard to see how you can get into it.
Finally, I also suggest running your computer's diagnostics, if it has one. This gives you a better picture if the problem is hardware (sound card itself) or software (drivers).
Hop these suggestions help!
Peace! :)
