Glad to hear that cleaning the filter got us to the next step-- Congrats on the progress!
Now Tell me more about what you mean by: ..." THe compressor doesn't seem to engage."
If you can reach the compressor piping, you can tell if the compressor is 'engaging' - by noticing a drastic difference in temperature -- the outlet pipe-- usually near the top of the compressor can-- / -- and the inlet pipr -- usually further down the side or near the bottom of the compressor.
THe Discharge pipe can get VERY HOT at the top, and the Suction pipe at the lower level can get VERY COLD (likely close to freezing) at the inlet-- the lower pipe.
Be very careful!!, if the compressor has been running a few minutes-- as the outlet pipe can burn your fingers!
Anyway-- if you notice a great difference in temperature, while the compressor is running, you know that it is moving gasses thru the system-- and thus should be creating the condensing surfaces needed to cause water to be removed from the air flowing thru the coils.
Please check this, and let us know what you learn.-- then maybe we need to dig deeper--- Like where is a frost (or sweat) line appearing, -- and more about air flowing details.
Hope this was helpful- MB
SOURCE: comfort-aire Dehumidifier bhd-651
Most likely the fan motor is broke. I have seen several units with bad fan motors.
SOURCE: Model BHD-301 dehumidifier compressor will
Hi bash123er,
If you're facing these problem that your dehumidifier is not producing water and compressor is shutting off then there are few things that needed to be checked on:
1. The very common problem with most dehumidifiers is the circuit board relay. If this has gone bad then it will require replacement.
2. The compressor has already gone bad. This is the problem if you notice a buzzing sound every now and then from the system.
3. You may also have a refrigerant leak. This happens when the compressor is running but coils are not getting cold at all.
4. There will be cause of low water production if the fan is not running and the compressor does. If fan is not running then you have to replace it. This also will result frozen coil.
5. Check to see also if your coil is blocked. This will also result into no water production.Air needs to be continually moved over the cold coil to get the water out of the air.
If you're not comfortable doing the checking and repair yourself then I would recommend that you contact a repairman.
Hope this helps.
Thank you for using FixYa.
