Control Panel button sticking on Normal mode
It is
possible that the machine does not start off the cycle because there are errors
due to feedback from the inputs. For the program to start up the main program
controller must initiate the INLET/MOTOR/DRAIN
pump/ valve to open up and allow each function to be driven starting from
the flow of water into the drum as also the drain valve to open to exit the
water at the point of the program cycle. If this does not happen then the
voltage at the valve/motor/pump must be checked or the fault relates to no
voltage from the controller. This means
the controller is a suspect. You will need to remove the unit and check the power to the processor, if there is a power fault it can be checked using a multimeter. Also if there is moisture , you must dry the unit as it can cause malfunction.
Thanks for your help Donald, we purchased the controller for $224.00 taxes in and the dishwasher is now working.
