My new Belkin N150 Wi-Fi Router immediately conflicts with my old Linksys WRT54G as soon as I plug the Belkin into the ethernet port. How is this occurring? How can I fix it? I've heard about setting a static IP for the Belkin.
Both the routers are having the same default IP addresses that's why they are conflicting.
Put only one router in the switch connected the a PC on the same LAN.
Open your browser and put the default IP address (like for most of the routers 192.168.1.1 or 192.168.0.1), hit enter and give the login ID and password (in most of the cases, admin/password orv admin/admin), go t configuration> IP settings> Static IP Mode> Change the IP from 192.168.x.1 to 192.168.x.2 (or any other other number except 1 and <254).
Save and reboot.
Now enjoy both routers plugged in simultaneously in the same LAN. :)
SOURCE: Belkin N router and linksys ip cam
You need to connect the camera directly to your computer and have it manually assign an IP Address on your computer so you could access the camera on the first hand.After that you need to range the IP Address of the camera accordingly to the IP Address of your network.
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
THE PROBLEM IS THAT THE BELKIN RTR AND THE 660 HAVE THE SAME IP ADDRESS THE QUICKEST FIX IS TO RENAME THE LAN IP ADDRESS OF THE BELKIN RTR
SOURCE: belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
SOURCE: my new belkin N 150 router is running slower than
IS the firewall enabled in the router?
This can slow it down.Also check that your ip address is correct.
Actually, I've now tried to hook up an access point (D-Link) but nothing will recognize the Ethernet port accept my Blu Ray. I've run a second line of Cat6 but still get no connection accept for the Blu Ray. I'm scratching my head.
