Normally the button and reset is in FRONT from the machine is you stand from the machine in the lower part, Is RED and at the side is reset button.
2) Test the fuse inside see the block diagram , test and replace.
3) Test the power cord for open, break
4) test the outlet wall, reset the breaker from you house, DO not use any extension cord. and proof again.
5) If you can NOT resolve the problem, you must call to the service tech,.maybe you have problem with some component, inside capacitor, transformer in the power supply.
God bless you
SOURCE: I have a Horizon elite 507 treadmill, everything
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem.
Methods to test a motor:
1)
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
2)
Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
Testimonial: "Many thanks for prompt response, seems that the treadmill works only when in the upright position and not the horizontal as per normal. Gonna have to learn to run up walls i guess"
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
SOURCE: I have a T54HR horizon treadmill. The problem is
best if you see the local retailer where you bought the treadmill. Obviously the switch, whick is a magnetic disc is not activating the sensor in the control panel and need to be looked at.
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
