Homelite Mighty Lite Lawn Trimmer  Logo
A
Anonymous Posted on Mar 12, 2017
Homelite weedeater mod. 26cs
This is my 2nd brand new mod. 26cs weedeater since spring this year. both of them exhibit the same characteristics. Neither will stay running after starting. I followed directions explicitly but won't stay running. This is particulary frustrating as my weeds are continuing to grow! I called Homelite service and they told me that this problem is very prevalent with this product and told me to take it to a service center. I did and they won't service Homelite products! Needless to say this is the last time I'll ever purchase another Homelite product!! Incidentally, I pulled/cleaned the plug, (many times) and changed gas numerous times and checked the ratio of 2cycle oil to gas. Again this latest one I purchased only has about 2 hrs of run time. By the way, there is no foam air filter as described in many reviews on the internet... just a plastic cover and it is clean!
roeb
Level 3:
  • Homelite Master 819 Answers
  • Posted on Nov 21, 2017
roeb
Homelite Master
Level 3:
Answers
819
Questions
0
Helped
384702
Points
2343
Try going to ebay and finding a carb for the model, some are as cheap as $12.
5 Related Answers
Anonymous
  • Posted on Jun 14, 2009
SOURCE: Brand new Homelite Mighty Lite 26cs String Trimmer
carb setting is too lean,need special tool to open,go to mower shop.This model also has problems with starter mechanism,I hope you have a warranty
Anonymous
  • Posted on Oct 18, 2009
SOURCE: carburetor adjustment for Homelite 2 cycle engine
I have the same problem with my MightyLite 26cc Blower/Vac. If it does start it runs rough on full choke and stalls on 1/2 choke or run. I've tried everything, fresh fuel, Seafoam, etc. Nothing works. First time I used it the exhaust burned a hole in my brand new Carhartt hooded sweatshirt. Best solution, throw it away, never buy another Homelite product and tell anyone who will listen what a piece of junk Homelite products are.
Anonymous
  • 110 Answers
  • Posted on Apr 15, 2010
SOURCE: weed eater repair (homelite)
sounds like it was put for a while with fuel in it ,,that hard ball keeps getting harder because it cant flow thru the system, that yellow knob adjusts your choke flap just to be set not pumped is going to have to be cleaned with carb cleaner
Anonymous
  • 468 Answers
  • Posted on May 28, 2010
SOURCE: GAS TO OIL RATIO
Homelite products are 40:1 gas to oil ratio
Testimonial: "QUICK & PRECISE!! A GREAT HELP, & GOOD WAY TO FIND ANSWERS."
Anonymous
  • Posted on Jun 17, 2010
SOURCE: wont start
Maybe,(as with my 1999 25cc) the fuel lines are leaking air at the tank, or the joiner of the fuel lines are cracked, if it is a new one, I would take it back and get one out of the box.
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
The head keeps falling off my weedeater brand weed eater
Add a split washer. Turn it tight enough to compress the split into a flat washer. The spring tension of the washer will hold it on. If not, you will need to add some Loctite.
Proper spark plug for homelite mdl ut2oo series weedeater
  • MFG Brand Name : Ryobi/Homelite
  • MFG Model # : AC00160
  • you can get them at any Home depot or any hardware store
3helpful
I have a Homelite Mighty Lite 26cs gas weed **** and the starter cord will not retract into the weed ****. How can I get it to retract so it can be pulled to start the weed ****?
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Weed eater repair (homelite)
1helpful
2answers
6helpful
3answers
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
