The battery shows that it is charged but will only start when it is jumped from the car battery. Though it shows charged, the same as a car battery, is it not charged "enough"?
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
SOURCE: I have an RZT50 Cub Cadet Mower that only starts with jump
it sounds like the starter motor is pulling to many amps for the battery to cope with. if its a 12v system it should not pull the battery down to less than 8.5 volts on cranking if it does the starter-motor is defective you can check this with a volt meeter across the battery terminals and see what it read as you crank the engine. hope this helps
SOURCE: battery wont stay charged
Hi..my name is Keith..you can take the battery to like an AutoZone or AdvanceAuto..and they will test the battery for free..it sounds like it has a bad cell in it..also i would look at the battery cable connections to see if they are corroded and make sure the ground wire has a clean connection to the frame..if this didnt help..please write me back
HAVE YOU CHECKED THE CHARGING SYSTEM? YOU COULD HAVE A BAD VOLTAGE REGULATOR. ITS REAL SIMPLE TO DO.START THE MOWER,PUT IT AT FULL THROTTLE.TURN A MULTI-METER TO VOLTS AND TOUCH THE BATTERY.YOU SHOULD READ 13.5-14.6 VOLTS.IF NOT GOOD CHANCE THE VOLTAGE REGULATOR IS NO GOOD.
SOURCE: my rider mower have to be jump started and once i
The battery will need to be replaced.
John
