Tricity Bendix AW1260W Front Load Washer Logo
Tom Duffin Posted on Apr 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
We have a Tricity Bendix AW1260W. It didn't do the spin on a wash and then had a beeping error signal of 5 beeps repeating. the manual doesn't explain that particular error signal. It did another couple of washes but without the spin cycle and the same 5 beep error signal. Now the machine won't rotate the drum at all, but will fill and drain fine. Not heard the error signal again, and have to turn the knob back to zero to get the door open. Have cleaned the pump filter. Has anyone heard of this 5 beep error signal? Thanks in advance for your time.
Marvin
Level 3:
Top Expert:
  • Tricity Bendix Master 85,242 Answers
  • Posted on Apr 24, 2017
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024051
Points
266281
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
3 Related Answers
A
Anonymous
  • Posted on Jan 05, 2007
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Anonymous
  • 38 Answers
  • Posted on Aug 26, 2007
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Ambari
  • 901 Answers
  • Posted on Mar 31, 2010
SOURCE: machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Loose Inner Drum on Tricity Bendix AW850W
Has the belt come off the pulley or the motor pulley? If not and it is in good condition has the belt stretched and not connecting properly or the motor slipped making the belt loose? Has the main pulley bolt come loose?
1helpful
2answers
Machine will fill and turn slowly but will not
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Tricity Bendix
try opening the small front panel at the bottom right hand side of the machine unscrew the drain guard and check for any blockages
1helpful
Motor won't spin, with flashing "End" light and 3 beeps
this should be a blocked pump or waste pipe or pressure switch ( round grey disk with small pipe off the drum)
1helpful
4answers
Tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
My tricity bendix washing machine flashing and beeping end light
Top Tricity Bendix Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
