When turning on it writes "Peavey" on the display - and it doesn't go away. It stays there until you turn it off again....
SOURCE: not recording
You likely have to format the stick from the unit before using. Also there MAY be a size limit for the useable stick.
For a flight case, it is best to find one that SPECIFICALLY mentions use for your unit. Having the supports in the right area to protect the controls is most important.
SOURCE: como puedo conectar mi Consola
Necesitas los drivers que deber?an venirte en un cd con la consola. Si no instalas eso, la PC no reconoce los AD converters que usa cada canal , que ser?a como agregar la misma cantidad de tarjetas de sonido nuevas, y es imposible que puedas grabar.
Si no tenes el CD, deber?as ingresar en la pagina del fabricante para descargarlos.
