It more than likely is the motor that has shorted. Remove lower rear panel, remove belt. Undo 2 screws that hold motor in place, remove motor plug, lever motor back to remove same,
Remove carbons and check for wear, also look at armature and see if there is any sign of shorting, clean armature with emery paper, fit new carbons, refit motor and belt, test.
If it still does not work, then in all probability it will have blown the main control board.which would require replacing.
