This carburator is on a Club Car Golf Cart
SOURCE: need setting for carb. adjuster on bottom of carb
Turn the adjusting screw all the way in until it LIGHTLY seats. Now back it out one and one half turns. Do the same adjustment for the throttle screw on the right side of the carb. You are now back to the stock factory settings.
Could you take a moment and rate my answer? Thanks!
SOURCE: wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
SOURCE: complete wiring diagram for a 1990 36volts club car golf cart
http://cartaholics.com/forum/index.php?showtopic=1880&hl=green+wire
See if this helps. Good luck!!
SOURCE: Air box and crank case fuel flooding problem
Well there only one way the fuel can get into the crankcase and that's from the fuel tank. The petcock must be draining and the float needles are not stopping the fuel flow. Do you have a prime position on the petcock? If so do not run the bike in the position. Try topping the tank off with gas and letting it sit for a while and see is the gas has gone down and then check the crankcase and see if there's fuel in it again. i still say its got to be your petcock.
Testimonial: "I will try it, thanks!"
