Simplay HD verified for compatibility
Turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
SOURCE: dvd is stuck inside and drawer will not open
Yes, it was a piece of the addhesive dot that was stuck to the back of the disk. I unplugged the unit (of course), removed the 10 screws holding the cover on the chassis and that exposed the disk in its tray. I could not manually open the tray still, but I was able to remove the tape dot from the disk while it was still in its tray. All is well now.
SOURCE: Harmon Kardon dvd5 player will
hi lowone.
here is a review i got from or HK DVD5 users. Unfortunately HK cannot have the issue fixed over the phone, so the best way for you to resolve the issue is to bring the unit to an authorized dealer and have it repaired. a replacement is also possible depending on how well your unit came in.
I admit it, I am very partial to HK products. I own 2 of their receivers (one of these for 2 years, the other for 6, and they both
work beautifully), but as far as dvd players go, they have done a very shoddy job in terms of lasting power. The first unit that I bought lasted almost a year (to the day). Then one day, the unit wouldn't come out of standby mode, with a few dvds trapped inside. HKs techs couldn't help on the phone, and they had me drive down to New Jersey to an authorized dealer, who kept it for 2 months (these can only be repaired in CA at a specific HK repair shop it seems). After making a bit of a stink, HK sent me a refurbished model. I've used this one about 15 months, but now this one is starting to act flakey. The picture will start to stutter, and break up, then will stop completely. This is on pristine discs with no smudges or scratches. I have reset the processor, but this doesn't affect the problem. So now, I don't know how About Schmidt ends, because the player encountered these problems towards the end of the movie. Very aggravating. I spent about $500 for this, then had the long drawn out problems with getting the unit repaired, and when all is said and done, these played for about a year each before problems were encountered. HK definitely has to work on improving the longevity of their dvd players. Until then, I think I will shop for a different brand, since this one is on its last legs.
Hope this helps,
regards,
voodoo
SOURCE: DVD Player tray Door Continues to Open
I had this problem and it turned out to be the gears on the door drive. There are two gears, one that engages the rack on the tray and one that has a slot that drives the clamping action to hold the DVD. These two gears were misaligned by one tooth. This prevented the gear with the slot from turning freely after the door was closed.
To fix it I had to take out the tray assembly, disasemble it, and reassemble it with the gears properly aligned. You need to remove the top and back of the case. Then take out two screws at the rear of the tray assembly and three screws on the circuit board attached to the tray assembly. Unplug the connections to that board. Slide out the tray assembly. Now you can pop the top off of the tray assembly by pulling out two tabs and sliding the top toward the rear. Now you can get to the gears to adjust them. The slotted gear should be able to turn freely for about 1/4 turn when the tray is closed. Make sure the pin on the clamping part is in the slot when you reassemble it.
SOURCE: dvd slider door won't close.
Hi, is it fully open, or just partially open?
Is it nearly shut but just jammed? If so have you tried inserting a flat peice of plastic and pulling the draw open. You could do this with no power to the dvd player, It might be that you haven't inserted the disc properly and it is wedged in.
Try all this and see how you get on.
Regards - Anthony
SOURCE: cant open dvd door:
You can force a dvd player to open. If you noticed there's a small hole in your dvd player as big as a paper clip. All you need to do is to find a paper clip and use it as a key to open ur dvd player.
