Ricoh Aficio 2022 Black and White Copier Logo
Posted on Sep 02, 2012
Ricoh aficio 3410 reset codigo sc542 - Ricoh Aficio 2022 Black and White Copier
sadashiva murthy
Level 1:
New Friend:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Nov 02, 2013
sadashiva murthy
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
16
Questions
Helped
6194
Points
37
Replace tirmistor and clear code by using clear mode 107........
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Apr 29, 2008
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Jan 25, 2009
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Jan 28, 2009
SOURCE: ricoh 3245c code is SC542
A SC542 error is a fuser problem. Did you have a power problem? You can try to reset it by turning the copier "ON" and once you have the code displayed on the screen.... Press the Yellow clear botton once - then the #'s 1 - 0 - 7, one at a time then press the Red Stop botton till the display changes..... Once, it changes turn the Main Power Off, not the one on the control pannel. Then turn it back "ON" and that should take care of it for you.... If it did not, you may have some more problems that can not be reset till they are repaired.. Good Luck
ginko
Ginko
  • 19396 Answers
  • Posted on Nov 19, 2009
SOURCE: ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Anonymous
  • 162 Answers
  • Posted on Dec 07, 2009
SOURCE: tengo una fotocopiadora ricoh aficio
Limpie o cambie si es necesario el thermistor de la unidad fusora, luego presione total clear key tecla amarilla, introduzca 107 y mantenga presionada la tecla clear stop tecla naranja, mas de tres segundos hasta que el tablero cambie a sertvicio, apague y encienda el interruptor principal y listo...
Buena suerte...
Service manual for Ricoh Aficio SP 5200 DN with all parts and troubleshooting
go to service mode.
press up and down button. then press ok. go to SP5810 and reset.
3answers
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
1helpful
Ricoh sp3510 sc542
This is the correct solution to resolving SC542 error on a Ricoh SP3410 SF and SP3510SF:
Press Clear/Stop button once and then press 1 0 7 and then the Start button to enter the "Engine Maintenance" in Maintenance Mode. Select "Fuser SC Reset" and execute..press ok. Turn main power on and off. Issue will be resolved.
Codigo sc 542 en ricoh sp 3510 como resetearlo
Oi por favor. Gostaria de resolver meu problema com minha impressora ricoh 3510sf que estar dando o erro sc542. Me manda resposta. [email protected]
36helpful
3answers
12helpful
3answers
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
1helpful
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
the reset should be all you need...
reset link
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
3helpful
Ricoh aficio 2232c sc542 error
Try this reset:
  • Press Enter
  • Press Enter
  • Press Enter
  • Power off and on.
  • Enter 107
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
12helpful
5answers
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
