JVC  42 in. LCD TV Logo
Posted on Sep 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My flat screen tv wont turn on...what does that mean?
Back2life Electronics
Level 3:
  • JVC Master 933 Answers
  • Posted on Sep 02, 2012
JVC Master
Level 3:
Answers
933
Questions
6
Helped
274348
Points
2189
Most likely your set has an internal failure and will need to be serviced. You can try unplugging it for a while, then plugging it back in to see if it will power up. But it is possible that you have a failure on your power supply board or the main board.
My flat screen tv wont turn on but the lite at the bottom just keeps blinking red what does that mean its a sony tv
Unplug the tv from all devices and unplug from the wall power source. After about 15 minutes, plug ONLY the power cord back in and see if it turns on. If not, than you will need to do a factory reset. With the tv pluged into ONLY the wall outlet ( no cable, DVD or internet connection) Hold the UP arrow on the remote than press and release the POWER button on the tv. This will reset everything and the blinking red light should stop. At this point you should be able to turn the TV on and off.
IF for some reason this does not fix your issue, visit HTTP://esupport.sony.com
Good luck.
Welcome to Product Support Get the help you need
Hdtv flashing green light for timer tv wont turn on
If the TV is a few years old the flashing green light means the bulb need to be replaced. That's why the TV will not show a picture. Check your owners manual on how to replace.
Hello my phillips flat screen wont turn on,any free repairs if its been under 2years
well, there could be different problems. I just repair one insignia that would turn on but no image or sound. I replace the main board to solve it. now if your tv is totally dead, meaning no power light, then your power supply is the problem.
1helpful
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
42 in. magnavox flat screen wont turn on
Does that mean, you still have sound but don't have a picture?
The TV (32" Dynex flat screen) will not turn on.
Hello, it does not power at all, means not eaven a power light blinks in the front of the TV, which also means there could be no power getting to the TV through the cheater cord, or a completely busted power supply due to shorted power regulators, lightning damage or surges in the power line. The easiest is to check the outlet, the power strip braker if you are using one, the power cord going to the TV. The rest of things would be inside the TV(power supply and power regs etc....)
1helpful
If you still get any indicator lights at all, then the 5v standby circuit is still working but the main power supply may be bad or it is not getting the turn on signal from the main board becuase the main board is faulty.
2helpful
2answers
Have xbox 360....got used,no instruct. book,was hooked to flat screen tv, no longer have flat screen tv, have regular tv hook up game comsole to tv, wont work.....why
If it was hooked to a flat screen it was most likely on high def. There is a switch on the connection to the tv to make it work on a regular defination tv. Just slide the switch over to regular and it should work. Hope this helps.
79helpful
3answers
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
