Onkyo TX-SR806 power switch clicks constantly for a while, and appears like it isn't receiving the signal from my cable box. There is also "crackling" of the audio. After a while, the HD channels would slowly start to "paint" the screen, The non-HD channels would come in more quickly. Now, over time, it got worse with no ability to get any HD channels though I can sometimes still get non-HD channels through the same connection from the cable box. The power switch still clicks. I have the same problem with the Blu-ray player connection so it seems it is not able to handle HD signals. I tried swapping all cables/inputs/outputs but it makes no difference. I also "reset" to factory defaults and as expected, it didn't help. Any ideas?
SOURCE: I cannot get video signal from my Samsung p1590
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
I probably should have mentioned that everything was working fine for years; this is a new issue. Also, that all connections are HDMI.
