Pwer train fuse in under hood fuse box totally missing...what does this fuse control?
SOURCE: 1991 lincoln town carTail lights and turn signals stopped working
One of the tail light bulbs can be shorted internally. Replace the tail light bulbs first. Try this cheap fix first.
SOURCE: clicking noise under dash
Nah, no msjor wire storms. If your lights are flashing, then I doubt its the flasher. It is more than likely your ABS system cycling. hAVE YOUR WHEEL SENSORS CK'D / ADJUSTED FIRST. gOOD lUCK.
SOURCE: 2003 Lincoln Town Car. intermittent starting. Have
Can you provide an email address where I can send some diagrams. This site only allows images smaller than 150k. Thanks
SOURCE: I have a 2000 Lincoln Navigator. About 2 weeks
Wow. I have a Mark VIII, so I can empathize...they really load these things up with electrical controls, and I know from experience to start with basics-get a digital meter and check your battery voltage when the car has been sitting for a few hours, it should be 12.5 volts. Next, check voltage when running-it should be about 15 when first started, gradually dropping down to about 14.2 after a few minutes. I cannot emphasis how important good power is on these power-hungry systems.
Check your connections at the battery, make sure the terminals are immaculate and the lugs are too-and you might try removing BOTH clamps and hold them together for a few minutes to discharge electrical components. Hook them back up (always hook up the positive cable first), and start the vehicle and let it idle for 5 minutes-then gently drive it for another five, to reset sensors. Assuming your battery and laternator are good to begin with, if you still have the problems you describe, you probably have a major malfunction with modules or even the ECM, something the dealer will have to diagnose with a Tech 2 scanner.
Testimonial: "That is helpful. I'm going outside right now with my multimeter."
i was troubleshooting the heater on a 2000 lincoln ls and i noticed that the HEGO'S relay was missing from the fuse box under the hood. Does it have anything to do with the heater and what exactly does it do?
