My acer 5520 wont load and sends me to a windows error recovery screen,
i can chhose safe mode but then it sends me to another screen Windows
Boot Manager that says
File: \Windows\system32\ntkrnlpa.exe
Status: 0xc00000e9
Info: Windows failed to load because the kernel is missing, or corrupt
I do not have the recovery cd's there should be one on the harddrive
partitioned i assume but no matter what i cant get a recovery option
ive tried the hold alt + f10 and it send me to a screen that says
Edit Boot Options
path: \Windows\system32\winload.exe
Partition: 1
Hard Disk: 53e114b0
[ /NOEXECUTE=OPTIN
any ideas???????????
It sounds to me like your laptops hard drive could be failing. The files may be on a damaged part of the hard drive so the laptop can't find them.
Excellent ! I am truly impressed that there is so much about this subject that has been revealed and you did it so nicely
Thanks
<a rel='nofollow' href="https://www.anikatechsupport.co.uk/"> Small Business IT Support London</a>
<a rel='nofollow' href="https://www.anikatechsupport.co.uk/managed-it-support//">managed it support</a>
<a rel='nofollow' href="https://www.anikatechsupport.co.uk/cloud-hosting-services/">cloud hosting services</a>
<a rel='nofollow' href="https://www.anikatechsupport.co.uk/projects-consultancy/">projects consultancy</a>
<a rel='nofollow' href="https://www.anikatechsupport.co.uk/cyber-security-continuity/">cyber security continuity</a>
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Do you have XP or Vista?
vista
