SOURCE: need to replace door handle
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally
made) that demonstrates how it's done.
model number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find
model number from the tag on the oven here.
These models use halogen
lamps. You must not touch halogen types with your bare skin, as the
oils
will shorten the bulb life.
You should be able to
get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
We're
SOURCE: lightbulb burned out for microwave model # KHMS
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
SOURCE: Looking to replace the plastic piece on the
They don't show the entire door assembly as being available.
But you can replace the outer door frame (outer door panel)part number 8184319.
At $167.94, it's not cheap. But you can get it here.
You have to
and then you'll see the previously hidden screw(s) you need to remove.
In some cases, you then
have to gently rotate the handle to unlock it.
You can find
model number here.
We're
