When I connect my UK - Playstation 3 to Sylvania HDTV (LC320SS9A) via a HDMI cable I get a message on the screen saying " Not Supported Format". Would be grateful for some help.
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
When i plug in my playstation via the hdmi port it says not supported format
