Electrohome dehumidifier stopped working
I have no experience of your particular machine but I have some
experience of my Wood's DS-15, another fine machine of the compressor
type that is built to last. They should be rather similar in design.
My first thought when I read your problem description is that you have
a severe buildup of dust inside the machine. On the Wood's, you loosen
the front grill and behind it you will see the fan, behind the fan is
the condenser pack, and then you get to the evaporator coils that are
visible from the back of the machine.
Maybe the configuration is slightly different on your machine but they
are built very simple these machines, easy to see what they need in order to
work as designed and you already know the most central and expensive parts seem ok.
I had some problems with low efficiency on the unit after six years
daily service in a laundry room for drying clothes, took it apart and
couldn't believe the amount of dust that was packed into the fine fins
of the condenser on its back side! Also extremely much dust on most
components like the fan.
I just took it outside and blew it clean from the front side with
compressed air, problem solved and machine performance went back up to
where it was when new!
I would imagine after a few more years of dust buildup inside, at one
point or another the dust will reach the fan and prevent it from
spinning. It is also possible of course that the fan motor is shot but
I'd start with a really good cleaning.
If that doesn't help I'd continue with the multimeter see if the
humidistat gives power to the fan and compressor when it should, if the
fan actually spins when powered, if the switches work. It should be
quite easy to track down the reason the fan doesn't spin, IMO. I believe you can buy replacement humidistats and motors if they turn out to be faulty.
