If the Kindle app is your preferred e-reading app, deleting a book is simple. It is known to you that you have a Library with all of your books in the app. And you can only delete book samples or PDFs you've downloaded to your device rather than the e-books you've purchased and stored in the Kindle Cloud.
You can check this article for help.
Guide: How to Delete Books from Kindle Devices & APP?
Hey , three steps are enough
Step1: Open the Kindle app on your iPhone
Step2: Tap and hold the book you need to delete.
Step3: Tap the pop-up "Remove from device" to remove the book.
more ways to remove books permanently. check this guide out!
How to Delete Kindle Books from iPad or Kindle Cloud
If you have piles of books in your iPad and want to delete them from iBooks to free up storage space, the easiest way to do that is deleting books in iBooks app:
If you have many ebooks to delete, deleting books in iBooks app may be a little complicated. But you can re-sync iPad with iTunes to delete books from iPad. This is also is easy to be done, and users only need to connect your iPad to computer with USB cable, and sync iTunes Books library with iPad. After that, iPad users will get the books from iTunes library to iPad.
http://www.leawo.org/tutorial/how-to-delete-books-from-ipad.html
Do you want to remove from ibooks or another program?
To remove from ibooks ,open ibooks ,tap edit on right,tap book to add check,tap delete,then delete to remove.
