SOURCE: Measurements for Rice
Most of my experience with the rice cookers is that they require a japanese rice Cup which is different than the japanese regular cup. makes a whole lot of not sense but i found a replacement cup at one of the local Japanese Markets if you had to you could use regular measuring cup and use the 160ml for your measure. also the cup has a "Inomata" on it so maybe the web can help you
Eat lots of Rice
SOURCE: Rice Measurements
You use one cup of water for each cup of uncooked rice. You end up with about 2 cups of cooked rice for every cup of uncooked rice. Different varieties, such as brown rice, take more water, up to 2 cups of water per cup of uncooked rice. If the resulting rice is too dry, you can add more water and restart the cooker.
I am not sure, but I believe that 16 cups refers to cooked rice, so you should not put more than 8 cups of uncooked rice in the cooker.
SOURCE: Rice Cooker instructions
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
You can obtain a manual for your rice cooker in two ways:
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
SOURCE: black and decker flaver scenter rice cooker manuel
http://www.useandcaremanuals.com/pdf/HS80035.pdf
is the pdf of the manual for this product
SOURCE: Can I plug this cooker into an Asian 220V 60Hz
If you put 220 into your cooker, it will destroy the heating element probably in a few seconds if not instantly. The heating element is a simple nichrome wire resistor and will not tolerate dissipating twice as much heat.
