The start button does not light up when pedaling , nothing lights up, what is the problem the battery if so, where is it located
I recomend that you read your instruction manual,and check the section troubleshooting. If you do not have go to download to the next web page: www.fitness.manualsonline.com or www.iconservice.com for FREE.
God bless you
Remove
the bolts or screws securing the console to the upright assembly. Lift the
console and confirm that the cable connections are secure. Remove the cover
from the console's battery bay and install a fresh set of batteries. Replace
the battery cover.
Detach
the ends of the pedals from the crank axles. Remove the left and right disc
shields and side shields. Inspect the interior of the base unit and locate the
flywheel.
Inspect
the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the
flywheel until the magnet passes in front of the nearby reed switch. Loosen the
screw securing the switch in place. Rotate the switch to reduce the gap between
it and the magnet. Tighten the screw.
Replace
the left and right disc shields and side shields. Reattach the ends of the
pedals to the crank axles.
Sincerely- G-d bless you
ernesto cuadra
managua,nicaragua
