First you will need to find out your wifi connection is ok or not basically, If you are having a slow Wi-Fi connection problem, its not the adapter, but might be the router. I found this article, which might help you to solve your problem. How to Change Wi Fi Channel for Your Router
Before anything else I would like to inform you that the high ping is likely caused b your connection rather than your hardware, if you can connect to an ethernet cable even temporarily then try to test it and see the results if you get the same results then it is your connection, since you are in Australia you can try these site: http://www.it-support.com.au/ they are located in Sydney and the most established IT Consulting Firm in the whole of Australia, these site can give you advice to almost all of your problems regarding computeers and Internet related problems.
You need a really good link so use one of these adapters (follow link please). hope this helps you.
link http://www.hawkingtech.com/products/prod...
Please help if you have any other suggestions :)
