The toe part of my heel toe shifter seems loose
SOURCE: My 2006 Road King toe shifter is stripped. How do
If that's where your shifter is stripped, you're lucky. Usually, they strip back where the shifter rod connects to the shifter pawl shaft.
To replace the shaft at the shifter lever, just take the floor board off and the bolts that hold the shifter bracket on. Slide the bracket off the shaft and take the shifter rod off the shaft. No problem.
Good Luck
Steve
SOURCE: How do I raise the
To raise the shift lever, take the bolt out of the shifter, pull it off the shaft and reposition it where you want it, put the bolt back in and tighten it up. No problem. On most bikes, you can get a heel/toe shifter to go on them. Look in most any aftermarket catalog. Try here http://www.customchrome.com/dcm/cc/index.asp
Good Luck
Steve
