I have a kenmore 72180592400 microwave over the stove. My wife did something yesterday and now it continues to reset itself. It keeps asking for the time to be input, which i do, then it clicks and resets itself asking to input time again. If i put something in to cook or warm, it will run for a few seconds and then stop, again asking for time to be input on clock. when i open the door, i can hear it click and reset itself again. I cannot figure where or how this was plugged in either. thanks for any assistance
SOURCE: microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit. The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
SOURCE: Kenmore elite microwave
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
SOURCE: thermador microwave from oven/micro/warming drawer
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
SOURCE: What does -F6- code stand for?
F6 means a problem in the control circuit board.
Try unplugging the microwave with the door open, then plug it back.
Try the solution that you find here, if it does not work the panel must be replaced.
SOURCE: Microwave won't function.
This
is usually caused by either a bad door switch, a loose door switch
mount (which are pretty simple problems to fix) or
occasionally a
problem on the control panel.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
Also see http://www.microwavedisplay.com/doorsw.txt
You can usually find
exploded views and order parts by entering your model number at the Sears
parts site.
A full Sears/Kenmore
model number has 3 digits, a dot, then 8 more digits, such as
There
may also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Here
is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Basic Microwave
Oven
Troubleshooting Tips
heatman101
