When i try to on the tv,it took a little time and than the images are blured like xray image and screen is full of colours.the charactors are moving but all are bunch of colours and colours are spread all over screen
SOURCE: My (sharp aquos lc 52d62u) tv fell to the ground. Image of broken glass and colored lines appear
Unfortunately the panel is cracked internally can't can't be repaired the whole panel has to be replaced. most times the panel will cost as much as you paid for the set. My son cracked ours when it was only 3 weeks old it doesn't take much force to ruin one.
Rustym62
http://www.the-tv-dude.typepad.com
SOURCE: Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place?
Anyway-
If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong:
1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or..
2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
SOURCE: I have a sharp aquos tv. If i leave the tv paused,
Sharp does not build plasma tv's. Its an LCD and yes older LCD's do get burn-in also. Its not as bad as Plasma, it is a bit of a problem it ruins the LCD panel. If out of warranty when this happens turn off Tv and allow it to cool down a bit, if in warranty have the replaced the panel.
Hope this help
Testimonial: "thanks mate"
SOURCE: Hello my Sharp LC60LE810UN 60 in LCD TV screen is
Initial communication reception error. result: communication line error or main cpu start-up failure. are you sure that the usb slot you used was for customer use and not label service only? there may be a way to reload software i suggest contacting sharp to see if that is possible or check support website for sharp.
