I put in the correct information for the date and time but as soon as my camera turns off, it resets to zeros
Replace the date battery following the instructions on page 194 of the manual.
Thank You so much. Forgot that battery was even there.
SOURCE: every time I set the date/time on my camera and
Replace the date/time battery on the side of the camera.
SOURCE: How do I turn off the date and time stamp on my
The menu on the camera controls the date and time stamp. Turn on the menu i camera mode, there are three choices, Camera, Settings and customize. Time stamp should be in the middle menu. Look for time settings and turn it off. All pictures have time and date always. The time/date stamp just makes it visible in the image.
SOURCE: I have a canon ixus
if the camera do not hold the settings ..it means the internal battery is faulty and need to be changed..(equivalent to a bios/cmos battery on computers....it is just a small size battery designed to power the memory for the settings when the batteries are unplugged )
try to see if this is happening when you remove the batteries for good..or all the time ...cause if it happens only when you remove the batteries..this may mean that it isnt equipped with an internal battery ..or it was faulty from the start or has issues in recharging ..
Solved. Thank you so much K_akima
