Engine stalling when letting off brake/clutch pedal or when trying to engage blades..safety switch bad ?
You need to unplug the 6 PRONGED CONNECTOR down by the foot rest plate on the right hand side. When you remove it, you may notice that 2 prongs are missing. That is because there is only supposed to be 4 connectors, so don't worry and think 2 connectors broke off. Just leave that disconnected and the brake/clutch will be disengaged from the engine to allow it to continue running AFTER YOU RELEASE THE BRAKE! :) Which is what you had a problem with, just like alot of us. I have a PT9000 series Craftsman with the 28 HP Kohler engine. I wish I could upload a pic, but you'll see it when you look at it. It is easy to get to, and you shouldn't need any tools unless it is seized on REAL good!. After I disconnected it, I started it, took off the brake, fired up the snow thrower attachment and was able to move it forwards and backwards.... Another issue that these are prone to is being able to run the engine, but the mower will not move forward or backwards (And YES it is NOT in Neutral! :-P) maybe another connector issue... LOL Soon nothing will be left connected except the starter switch at this rate!.. Anyways, Theres your fix!
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
SOURCE: Craftsman riding mower Model 917.270824
I do not believe there is a manual available to the public for troubleshooting, however, you have at least 3 switches to tell the mower to stop when blades are engaged or clutch pedal released.
Seat switch
pedal switch
mower engage switch
The pedal and mower lever switches are identical, and have two sides, one for starting, one for blades turning. One side can fail. The pedal switch is on the frame very close to the pivot point of the pedal/shaft. The mower switch will be under the dash close to the bottom of the lever.
1) Locate and inspect the switches for broken or pinch wires, switch housing, or loose mounting, and how each lever or pedal engages the swtich.
2) This is a picture of the wiring so that you can get a better idea of location.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00011&componentDescription=SCHEMATIC%20DIAGRAM-TRACTOR&documentId=P0811014&blt=06
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00001&componentDescription=ELECTRICAL&documentId=P0811014&blt=06
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: I have a 15.5 hp ohv briggs n stratton on a
There is a switch underneath the seat that will shut the engine down if the mower is engaged and you are not on the seat...that switch is bad and it thinks you are not on the seat so it shuts you down...
heatman101
SOURCE: Mower starts, but when I let off clutch, it dies.
when the seat goes out of adjustment due to the crappy adjustment bolt design, the bolt inadvertantly engages the safety switch under the seat.
