Momentarily and temporarily..I just removed my password to have an access. I tried registry recovery..no effect at all..I tried optimizing and cleaning neither has effect...what should I do?Should I reformat or find and troubleshoot the problem? thanks for rendering suggestions.
Hi quiambaonest
i would like to inform you that you are on the wrong way with your diagnosis because this is not a software issue that you can solve by formatting.
this is symptom of a lcd or video card failure.it would be great if you can try and test it with your friend's video card.
there is an easy diagnosis . just connect a projector or external monitor.if that works normally you are in trouble with the monitor.
get back to me when done with these tests so that we can proceed further
When streaking vertical dotlines that appears only on dialogue boxes-heading from right to left on dialogue boxes continuosly..when stop voluntarily..i will delete them..and there i can input my password or type messages..but screen monitor or LCD is quite normal & perfect..no distortions or lines...tosum it all it's perfect for viewing...I just wonder it appears on dialogue boxes !!!
Correction vertical lines on dialogue box streaking from left to right. When sit stopped.. the dotted lines I'll delete them...it's only then I can access my window.
