Have you made any changes before the blue screen appear? installing a driver maybe? if you have,try to undone those changes by booting with Startup with last known good configuration (undo recent registry and driver change),use System Restore,or Roll Back device driver,Scan your computer for viruses
and Return BIOS settings to their default levels,go to BIOS by pressing F2 or del exactly after you press the power button and the screen show up
if it still in blue screen,that's probably that some of your system file is missing,and you need to reinstall your operating system
Please let me know if it's working or not,i don't like to abandon anyone,and thanks for using fixya
SOURCE: My laptop says a problem has been detected and
doest it comes with bluescreen please be more descriptive about your problem
SOURCE: windows xp wont boot! ,it say *in a blue screen*
on of your hardware file was not connected properly... you better check it.if not..... reformatting will surely cured it.
SOURCE: Dell XP restart problem
This error comes due to 1. RAM problem or 2.Hard disk problem or 3.Software/device driver problem or some times 4.Virus problem.
First you run the system in safe mode (pressing F8 at booting) - restore the system (start-programs - accessories - system tools - system restore). PC will be restarted and if it runs well then fine. If not again run in safe mode- uninstall few softwares or utilities, clear the temporary files, few drivers - restart the PC it may run well. If it does not run in safe mode the problem may be due to virus or critical RAM problem (main suspects, as the error may be for different reason).
Now you format the hard disk and install your applications and drivers one by one and restart and check whether the problem repeats. Failure with the step you should change the RAM. With all failures - motherboard should be repaired and you have to give to the service center.
SOURCE: i have a dell inspiron 6400 and every time i turn
Hi there, This error can either be caused by a
problem with an IDE cable or the BIOS in which case you just replace the
cable or reload the fail-safe default settings in the BIOS. However,
most of the time this error is caused by some sort of problem with the
volume. To fix this problem you will need:
We wish You a very Happy New Year.
Which is the operating system? I would give you steps for windows vista.
Post back if any other.
You "might" be able to fix it this way (assuming its a glitch in the drive).
UNMOUNTABLE_BOOT_VOLUME STOP 0×000000ED
http://gregscomputing.com/?p=20
From a Operating system disk - (you can also try from the Dell Recovery Console)
Run CheckDisk on it from Operating system as below
chkdsk /f /r
Spaces after k before / and after f before
Fixing the problem:
More options which "might" work.
This tells you how to access the System Recovery Options and/or use a Vista Disk
http://windowshelp.microsoft.com/Windows/en-US/Help/326b756b-1601-435e-99d0-1585439470351033.mspx
Try StartUp Repair from Recovery Options or Vista disk.
How to do a Startup Repair
http://www.vistax64.com/tutorials/91467-startup-repair.html
Unable to boot in windows vista- windows boot configuration data file is missing required
information - Repair Corrupt Boot Manager
http://www.troublefixers.com/unable-to-boot-in-windows-vista-windows-boot-configuration-data-file-is-missing-required-information/
How to use the Bootrec.exe tool in the Windows Recovery Environment to troubleshoot and
repair startup issues in Windows Vista
http://support.microsoft.com/kb/927392
How to fix "BOOTMGR is missing" in Windows Vista
http://cyberst0rm.blogspot.com/2007/04/how-to-fix-bootmgr-is-missing-in.html
Error message when you start Windows Vista: "The Windows Boot Configuration Data file
is missing required information"
http://support.microsoft.com/kb/927391
Vista Tip: Repair "BOOTMGR is missing" error - a quick how to
http://lifehacker.com/251733/vista-tip--repair-bootmgr-is-missing-error
See this section here - To repair/rebuild the Boot Config Data Use the Bootrec.exe Tool
http://www.vistax64.com/tutorials/163304-dual-boot-using-free-partitioning-software.html
If you do not have a Vista disk you can borrow a friends as they are not copy protected.
Your System maker will also sell the physical DVD cheap since you already own Windows.
Also you can make a repair disk on another computer.
If you need to make repair disks - these help repair Windows not re-install.
How to Make a Bootable Disk in Vista
http://www.brighthub.com/computing/windows-platform/articles/7050.aspx
Download: Windows Vista x64 Recovery Disc
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
How to Make a Windows Vista Repair Disk If You Don't Have One
http://www.howtogeek.com/howto/windows-vista/how-to-make-a-windows-vista-repair-disk-if-you-dont-have-one/
0x000000ED
http://www.faultwire.com/solutions-fatal_error/UNMOUNTABLE-BOOT-VOLUME-0x000000ED-*1236.html
Have you been able to gain access to the Setup/Settings (BIOS/CMOS) as you boot?
If not you are spinning your wheels as the I/O issue is below the operating system level.
If you can get in regularly then the problem might be repairable. Intermittent access to
the BIOS is just further proof that the system has serious hardware issues.
Frankly if you can access the system at all I would backup the data off the main drive
and preferably using several techniques for redundancy off the computer entirely. Then
I would format the drive and re-install Windows to do as much as possible to remove the
I/O issue from being software related. However, doing this is not likely have a high success
rate.
0x000000ED is a very serious I/O Error :
The UNMOUNTABLE_BOOT_VOLUME bug check has a value of 0x000000ED. This indicates
that the I/O subsystem attempted to mount the boot volume and it failed.
There is a possibility that the root cause could be a loose or defective contacts or cabling
though that too only holds an outside chance.
Another possibility is readdressing or updating your BIOS however doing that on an unstable
machine has very real additional risks and should be done by technical support in this case.
If needed :
Dell Support
http://support.dell.com/
Dell Drivers - Product Manuals & Warranty Info (left side) - Tech Support and more
http://support.dell.com/support/index.aspx?c=us&l=en&s=dhs
Dell Forums
http://en.community.dell.com/forums/
These might help.
How Do I Start My Dell™ Computer in the Windows Recovery Environment (WinRE) for Microsoft
Windows Vista?
http://support.euro.dell.com/support/topics/global.aspx/support/dsn/en/document?c=uk&dl=false&l=en&s=gen&docid=28BD8867DEE5A319E040A68F5B28308B&doclang=en&cs
How Do I Start My Dell™ Computer in the Windows Recovery Environment (WinRE) using the Microsoft
Windows Vista® DVD?
http://support.euro.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=6DD3C43766BBCE7DE040AE0AB5E16CC1&docid=28BD8867DEC7A319E040A68F5B28308B
What Is the Microsoft Windows Vista® Recovery Environment (WinRE) and System Recovery
Options Menu?
http://support.euro.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=71BD6AA02AEEB8AAE040AE0AB8E15482&docid=226362FD0FD557B4E040A68F5B28624E
Hope this helps.
