I forgot my password i can only log on as guest
Forgot laptop password? You can use Smartkey Windows Password Recovery to help you to reset forgotten laptop password, and you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
SOURCE: password help
please elaborate on main password, do you mean windows password? if so: 1) download a password reset disk (I can create one for you and email it) for a small fee. 2) boot laptop, when you see acer power on logo, look on screen for recovery or setup. Most likely F2, F6, F10, or F12 key. That will bring you to an Acer recovery menu. You can restore the laptop to factory, however you will lost all your personal data, and will haver the factory loaded software .
SOURCE: forgot login password so my ibm laptop is completely locked what do i do?
Are you using XP, you can boot in Safe mode and log in as Administartor(usually it does not have any password), so login with Admin account and remove the password of your account. and then restart the system to Normal mode to get your system working.
But unfortunately in case if it is Vista, there is no other option other then formating the whole system.
SOURCE: forgot asus laptop password Windows vista
To reset your ASUS laptop Windows login password, I think you can try this password recovery software, fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. You can do it on your own, no need to send it to a computer shop. Regards.
SOURCE: forgot password for my laptop compaq armada 1750
At last, I found it and reset my windows password successfully.
You can reset windows user account password in safe mode(F8 when booting up). But if you forgot administrator password, you must reinstall windows OS or use the Windows Password Seeker
