SOURCE: I have a lg lmv
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.......
Hello & Welcome to FixYa
Microwave not heating could be due to a faulty door switch or an internal blown fuse. Check out the parts for your microwave from this link--- Link. Please get back to me if you have any other questions.
Kevin
Chances are the panels separate as shown in the photo I have attached below.
Panel replacement can usually be done without removing the door from the microwave.
In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges.
I generally do not advise removing the hinges from the microwave.
Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in.
Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices.
By the way, where did you get the part? I'm trying to find a good Goldstar / LG source to recommend.
