Kill switch is not on. Have good spark on new spark plug. Have good gas in tank. This saw has very few hours on it. Tried priming carb., tried priming cylinder.. match will ignite fuel and it works in other saw fine.
Could exhaust be causing problem? Or air mixture?
Pull the muffler off and look for scoring on the piston,the 455 had a problem with running lean from factory and burned up a lot of pistons and cylinders
Remove exhaust , check piston make shore you have a chance,
check ex screen isn't blocked.
check choke isn't stuck on,and half throttle is working. get back to me from there.cheers
I have the same problem with a 353 plenty of spark and fuel, good piston & cylinder but will not fire at all
xp440 chainsaw starts and runs good until it gets hot put new spark plug still no better
