SOURCE: Annoying Problem with my creative zen v
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update.
SOURCE: Creative Zen V Plus volume control unresponsive
someone probably put a password in the volume control thingy
to change just go to settins and then where it says volume
if you cant go in it might be somone changed the password
SOURCE: Zen Xfi hanged-up
Use the reset button by pushing in with a needle. This is on the bottom of the unit.
SOURCE: Creative Zen doesn't respond to the buttons or music selector
Most Creative zen mp3 players have a slide power on/off button, when slided completely back it sets the mp3 player on key block, maybe it's on key block.
SOURCE: how to break volume restriction
Boot the ZVM into Recovery Mode and select Cleanup from the menu. This will reset any user defined settings, including the passwords.
To boot the player into Recovery Mode, do the following:
