I can't get the buttonhole in the exact position for an ending and starting position. What am I doing wrong?
Some machine have a button hole lever that has to be pulled
down, before they work.
are you using the button hole foot?
if the machine is mechanical, are all the dials set for button hole?
if the machine is electronic are all the settings correct?
also change the needle
if you have the button hole foot on & the button hole lever is down
& a new needle,, the it is possible that the machine needs to be
checked to see if there is something wrong with the buttonhole
function
SOURCE: Singer 7462 buttonholer
generally most sewing problems are due to sticking parts because of non usage as =you have stated or because the tension has been not set right. what I suggest is that you take the time to do some cleaning of the machine like what bis pointed out in your manual use a light weight mineral oil to wipe the moving parts with, but not too much. also adjust the tension of the foot so there is pressure on the material as to move it while sewing. after all the cleaning and adjusting rethread the bobbin and make sure it is seated properly also rethread the need and make sure the thread moves freely from the spool. this should do the trick. please rate this
SOURCE: one step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
SOURCE: i can't seem to get the buttonhole attachment to
I am so excited to share this with you.
I was having the same exact problem and I found the solution here:
http://kraftykuka.blogspot.com/2008/11/benjamin-button-hole-maker.html
the answer was pulling down the button lever!
i hope it helps you too!
SOURCE: Elna 6003 just stopped working
I need a manuel for a Elna 6003 quilters designer where can a purchase one???
SOURCE: need a manual for Elna 6003 Quilters Dream sewing
Here is one - http://cgi.ebay.com/ELNA-6003-QUILTERS-DREAM-INSRTRUCTION-MANUAL-50-PGS_W0QQitemZ260342126317QQcategoryZ41246QQcmdZViewItem
Testimonial: "I am so pleased that I was able to get my manual and now know how much I can do with my machine. Keep up the good work. We all need to work together."
