RCA P52960 52" Rear Projection Television Logo
Posted on Aug 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My rca d52w26 convergence is gone.
It is like watch 3d tv. I heard there is a way to reset this by using the remote as i can not find a autofocus, or convergence, or any other button that may work. Can you tell me the correct sequence of buttons to try on my remote.
Anonymous
Level 3:
Top Expert:
  • RCA Master 14,553 Answers
  • Posted on Aug 28, 2012
Anonymous
RCA Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715189
Points
48227
Look in the on screen menu for convergence and if it is not there you have a open ( bad ) protection part on the main board, a kit exists for most of these sets for this===buttons alone will not likely help here.
the convergence menu missing is a result of this and the part in question is often bad because of bad solder connections.
If you need more info let me know.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on May 22, 2006
SOURCE: rca 52' projection convergence problem
Its a good possibility that your convergence problem could for now be cold solder connections on the driver ICs on the convergence board. The longer you use it the more of a problem its going to surge those ICs till they go bad and maybe cause other componet falure as well. If your not a technician i would have this set serviced asap before it becomes a major repair Good Luck
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jul 17, 2008
SOURCE: D52W26 Convergence board
Yes the D52W20 and the D52w26 are both ITC222 chassis they are exactly the same
Anonymous
  • 1030 Answers
  • Posted on Jan 10, 2009
SOURCE: Divergence not working on RCA HDTV monitor 52" D52W26
sound like the common fl231 fuse problem. consult the fl231 problem article under the tips and tricks section. this is probaly the simplest most inpensive repair on this set
Anonymous
  • 6784 Answers
  • Posted on Feb 13, 2009
SOURCE: 3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 14, 2009
SOURCE: 3d rainbow pictures..with colorful waves..and no convergence menu to fix it.
You will need to replace the FL231, DL231 and CL230 you can get the parts with free instructions with pictures at the following link. The parts are all listed under the RCA parts category total cost is about 11.00 http://servicemanuals.vstore.ca/
1helpful
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Fixing rca D52w26 convergence problem can you try fixing with remote
No,must replace parts,These websites,have convergence kits for many DLP TVS.Tv Repair
World.com,Tv Repair kits.U know how to solder right?
I was watching tv just fine then i heard a pop and the screen went almost 3D like
you have convergence ic gone bad and mybe the fuse is also open the part number will start with STK SOMETHING
Tv looks like it is in 3D
Sounds like your convergence amp board has gone out and will need replaced. If you feel like giving it a try yourself this web site has them fairly cheap and they have an 800 line if you need help determining your board number.
http://www.moduslinkptstvboards.com/Default.aspx
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
1helpful
2answers
RCA D52W26 rear projection. 2 years old. 3 times and powers out.
Try replacing CP150, CP114 and CP120 first cost about 12.00 with free instructions available at the following link under the RCA parts category
RGB lamps are not aligned
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
The convergence is way off on my projection rca tv - i lost the manual but i have set it before in a menu but caint remember how to get to it Was watching a movie, tv shut off and powered back on by...
It should be in the options menu. If not often RCA will drop the option when the convergence ICs go out and often the set will shut down. Heres alink that should be able to help you get a manual and parts if needed. If they dont have your manual leave an email and they should be able to get one quckly usually within an hour or two.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
