Machine is about 25 years old
SOURCE: manual fornecchi-alco sewing machine model 301
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
SOURCE: I just replaced the belts on my Necchi 535FA, but
If the belts are not tight enough they will slip, they should all be fairly tight but not like a piano string if you know what I mean.
As you do not describe what the machine is doing wrong I can not really say any more at present, except make sure there is no oil on the belts and the machine has no tight spots when you turn it over by hand.
SOURCE: I need a user manual for a Necchi Alco 2200 sewing machine
Contact the individual who posted this answer.
You should also try www.sewusa.com. I found the manual for a used Necchi 521FB I brought. Hope that helps.
SOURCE: should I oil my Elna 3005 sewing machine?
Many of the new models do not require oiling.
Check the maintenace section of the manual for cleaning the shuttle area. Sometimes lint can build up and cause the machine to get noisy.
If it has been over a year since the machine was serviced, it may be time for a proffesional tune-up.
