I cant figure out how to rewind the rope
That is the fun part! You have to leave the handle end free, as in no handle on it, put a good knot in one end of your new pull cord, feed it through the hole in the pulley, feeding it out so you can pull it back into the space where the pulley is. Should be a slot on the pulley to bring it up in. Wind pulley against spring, same direction as normally pulled when starting, will need three to six rounds, can't tell how many cause it varies. Stick cord out hole to where handle should be while keeping tension on spring so you don't lose it. Tie handle on and try it. You may have to adjust rounds against spring and length of cord until you get it right. Good luck!
