Technics SL-DZ1200 CD Player Logo
magdalena ruth mendoza Posted on Aug 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No disc display - Technics SL-DZ1200 CD Player
Sam Palermo
Level 3:
  • Technics Master 1,267 Answers
  • Posted on Sep 24, 2012
Sam Palermo
Technics Master
Level 3:
Answers
1267
Questions
Helped
256152
Points
1842
This can be caused by many hours on the unit or a bad solder joint on the PCB. It will need to be seen by a repair Technician.
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
1helpful
No dics display
That means it can not focus on the disc or that you are using the wrong disc type like a DVD in a CD player. Try cleaning the lens.
1helpful
Get display : NO DISC or BAD DISC
Probably the laser lens needs cleaning.
Purchase a laser lens cleaner disc at Radio Shack ($13). No chemicals are involved.
Read & follow the instructions. It cannot harm the player if not done right.
Sep 30, 2009 • GPX PDL705
1helpful
Display reads No Disc despite all the discs checking out.
Hi, the optical lens assembly has failed. this is triggering the (no disc) error code. you will need to replace this failed optical assembly.
Will not record disc-to-disc
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
3helpful
SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
MDS E12 displays 'Over' and ejects all discs with 'Read Error'
"Over" is always lit in the display. It just marks the end of the VU meter scale.
You have a drive problem. Nothing to do with your track 15 operation.
I would suggest reseating the drive ribbon cables, oxidation of these is a common theme with my MDS-JE530 which shows the same symptoms periodically.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
